Originally posted by mark4323
View Post
Toyota Timing belt for the last 15 years - Rubber.
Mitsubishi Timing belt for the last 10 years - Rubber
See a pattern emerging here? According to your logical some of the most popular cars on the road are all problematic due to rubber timing belts.
The only maintenance that should be required to a timing belt is replacement at the interval specified by the manufacturer. Don't replace the timing belt then, be it on your own head! They've all been self tensioning for quite some time. All you need to do is replace and install it properly, and there'll never be an issue.
Chain timing belts come with their own set of problems. Chain does still stretch and wear, it's generally a much bigger job to replace, it's noisier when running and presents the same potential for failure as a rubber belt. If you'd ever replaced a timing chain on an overhead cam'ed engine... you'd change your mind on just what a great idea they are compared to changing a rubber timing belt...
