Mkv r32
  • Mkv r32
    is it worth TUNING it?
    currently with forge intake, non res milltek exhaust and forge oil catch can
    worth the extra 10kw?
    does it really save abit of fuel?
    which tune is trustworthy?
    located in syd
    steve
    great standard or lightly modded car. Not worth modifiying it IMO - you would need to spend a considerable amount (supercharge or turbo) to make a considerable change in performance.
      yerh i thought it'll be a waste of money considering its a n/a straight 6
      cheers ben
        cheers ben
        Its not a straight 6, its a v6, very narrow angle but still a V.
        2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
          APR has a 15% off sale at the moment. Why don't you find a local dealer and get a trial flash to see if you like it?
          R32 MY08 3Dr
          Deep Blue Pearl DSG
          Haldex Gen 2 + Switch Neuspeed TAI Whiteline 24mm RSB and BSH Endlinks
          Forge intake Alpine/Focal ICE
            yes im aware its a v6, the VR6 is also able to use the firing order of a straight-six engine.
              located in syd
              steve
              If money permit, lookup United Motorsport / Blue Water Perfomance E85 tune. Get it as flex tune that is self switch-able between fuels + get DSG tune.
              It will wake up the car a bit on E85.
              Other than that, no point. R32 is farly nice out of the box, you cannot get any significant increases out of it, unless throwing considerable amount of cash in aka cams, SRI, turbo/super.
              .:R32T, Stock Internals | C2 stage III hardware | Schrick 268/272 | SRI by UM | DSG & Engine Code by UM | Side mounted oil cooler
                i had the APR trial tune on my mk4 R32, it was really nice, it revved much happier and it was more responsive. I liked it but APR wanted $1500 at the time and i just could not justify it.
                Just had a look at their website, single program is $795 an i think its worth it. I wouldn't go for any more than that, its just useless toys that you will play with twice
                1991 BMW 318is RED E30
                  Where did you get the UM tune in Australia?
                  How much is it?
                    How much is it?
                    I actually got UM from USA to send me 'special' cable to enable ECU flash. Then set up my laptop as a 'dealer' and flashed my ECU and DSG via internet.
                    Cost, do not know how much it is now. Email them, see what are the options. They may have distributor near you.
                    UnitedMotorSport.net | United Motorsport Performance Software
                      With an intake and an exhaust on your car, getting a tune will bring out a bit more in the car. You'll feel the difference a tune gives you but don't expect a huge change - it does round the car's engine performance out though - plenty of options such as APR, GIAC, Optimum Code etc.
                      If you have a DSG, there are tunes for that too and there is apparently a quite noticeable change (run a manual myself). From all reports a DSG tune worth checking out.
                        Mkv r32
                        The tune will compliment your intake & exhaust - you will notice the flat spot in mid range is removed
                        .:R32 | GIAC | HALDEX II | MILLTEK | BMC | WHITELINE | A-ROTORS | HAWK
                          Hmm..
                          Since this is a R32 thread - I figured I'd post here rather than make a duplicate...
                          going to inspect a R32 MKV tomorrow.
                          Are there any common issues I should look out for? Thanks
                            How did the inspection went?
