MKV Jetta 2.0TFSI (147kw)
  • MKV Jetta 2.0TFSI (147kw)
    Hi,
    My brother just put a deposit down on an 06 Jetta 147tsi. Anything in particular with these cars which is prone to failure? it has similar kms to my GTI (100k+) so I have some idea of what to expect.
    My current short list:
    Check PCV valve
    Check CV boots
    Check for engine mount cracks
    Check if timing belt/ waterpump has been replaced
    Check if plugs have been done
    Check that the last DSG service was on at 60k
    Any help appreciated.
    Cheers,
    Jesse
    MKV GTI
    TFSI and TSI which you both mentioned, are different engines (obviously). Also, i am not sure the TFSI is 147KW in the Jetta?
    Also, check the Diverter Valve, Elec Windows, A/C
      Yeah sorry to clarify its the same 2.0T engine which is in the GTI, the 147kw.
      This model:
      http://redbook.com.au/cars/research/...&Ridx=1&eapi=2
      MKV GTI
        Originally posted by jessv3 View Post
        Hi,
        Check PCV valve
        Check CV boots
        Cheers,
        Jesse
        Add Check airbox/engine cover for cracks to the list
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
