Heya all! I'm having a slight issue with my jetta upon startup, firstly after it cranks over and fires it sounds like a rattly old tractor ( I know that's inherent with diesels but my main daily drive is a heap of junk Triton 4x4 diesel and that Doesn't sound as bad) further more, occasionally It won't actually fire / I have to crank it over for quite a while for it to fire. Could this be a DPF issue or something more sinister? I will upload a video that might clarify this... Thanks !
07 Jetta Tdi startup issues....
Interesting. Doesn't sound like a DPF issue. Are you even sure you have a DPF? I have an 07 Jetta and i don't have a DPF.
Does it only happen when its a cold start? My Jetta is pretty noisy on cold start.
Which suburb are you located? Might be wise to do a quick scan to see if you have any error codes. Happy to swing by or meet you somewhere if your near Chaddy.Last edited by getjet; 05-10-2012, 10:01 PM.
hey getjet it happens pretty much all the time (the noise that is) the non-starting issue is sporadic.
i live like 5 mins from chaddy hahaha!B6 Tdi Wagon - Reflex silver, heated memory leather, sunroof, 300k+
MK7.5 Alltrack 132tsi Premium - Tornado Red, Sound & vision, Sport lux packs + retrofits
