Hi Guys
Went to use AC today, and no go. Wife then mentions its been like it “for a while”.
Dec 2004 (mk5) 2.0tdi.
Fan blows air, temp control works for heat but no cold air, there is no change in engine when the AC is turned on/off (used to see the fuel meter go from 0.6 to 0.9 l/hr), so I assume that the compressor is not cutting in.
I see no mention of AC fuses in the manual.
No Faults show in VCDS
Any clues pls on where to start for fuses and relay for AC? Or is this a common bigger issue?
Many thanks.
Many thanks.
