Originally posted by buzuki
View Post
mk5 gti rattle/sound during idle
Its no theory , it is the injectors unless you are having a distinct knock, in this case you may have a worn bucket and or a worn inlet cam, this happened early in thepiece but there is still a few out there, AXX is a candidate and early BWA, later ones were better but they are still noisy
JmacAlba European
Went to VW today cos the engine noise (sort of a constant mechanical thrash that seems to come on a idle) is givin me the ****s. Turns out after a bit of probing it appears to be the timing belt cover rubbing on the timing belt! bad news is its a bitch to replace, including removing the engine mount. So I might just put up with it for a while. Until I decide to put on some VWR engine mounts!Volvo S60 RD T6
