Can anyone please inform me with the mk5 gti fsi engine sound , is it supposed to have a tappet sound , as many people have said including the seller of this car that it is normal , in many other threads from around the world ijust cant get a concrete answer to this .....
1 of 2
2 of 2
mk5 gti rattle/sound during idle
I have a 06 gti - has 96,000kms - dead stock and as far as i know in good working order. It makes an audible "tap.tap.tap.tap" at idle.
Whether this is the valves , or injectors i have no idea - but the car is fine. Seemed to be the same noise with all gti's i checked out too.
Overly loud tapping could indicate low oil/stuffed pcv system/loose upper head parts etc.
Its the timing chain that goes around the intake cam and camshaft adjuster. The only way to get rid of it is to replace the intake cam, the chain and the camshaft adjuster. You cant just replace one as they allwear together. I found this out the hard way. These are the parts you need:
Volkswagen Golf V 2.0T > Engine > Mechanical > ES#281130 Intake Cam - Revision "B" - 06F109101B
Volkswagen Golf V 2.0T > Engine > Mechanical > ES#281129 Camshaft Adjuster Magnet - 06F109088J
Volkswagen Golf V 2.0T > Engine > Mechanical > ES#280410 Timing Chain - For Camshaft Adjuster - 06D109229B
Volkswagen Golf V 2.0T > Engine > Mechanical > ES#281137 Timing Chain Tensioner - 06F109217A
Its around $700 shipped from ECS or around $2,000 if you buy fomr VW Oz.Volvo S60 RD T6
When your engine is warn and being running for about 30mins and you can hear the "diesel noise" from inside the car when your idling, that means that you need to replace what "thezoneR32" said in the previous post, the timing chain and tensioner. that being said, the fsi does sound like a diesel at idle, because of the direct injection, however if it's loud when the engine is warm then you might need to replace the suggested parts.
Before too many diagnoses are provided without actually listening to it, it's worth taking it to a specialist for checking out prior to jumping to conclusions. The direct injection (FSI, TSI, TFSI) is very noisy and can be interpreted as a tappet type noise. There's a few highly recommended independents in Perth so pick one that's in your area and get them to check it out.MY08 Blue Graphite GT TSI DSG
Its the injectors . Ive finally got an FSI specific injector tester and can finally find out the flow rates of some of these injectors !
The reason why they get noisy is mainly due to the carbon being built up on the tips causing uneven spray patterns . Then you dont get the adequate fuel and the injectors are opened for longer and Im pretty sure the ecu also raises the pressure ( need clarrification on that though)Bug_racer supports the rebellion of the euro revolution
Originally posted by mk5fsi View PostWhen your engine is warn and being running for about 30mins and you can hear the "diesel noise" from inside the car when your idling, that means that you need to replace what "thezoneR32" said in the previous post, the timing chain and tensioner. that being said, the fsi does sound like a diesel at idle, because of the direct injection, however if it's loud when the engine is warm then you might need to replace the suggested parts.
Originally posted by dubsweeper View Postbeing a fsi 2007 my08 it would be a timing belt , so i think think what i have seen through other comments around the place is the way it just sounds
Originally posted by thezoneR32 View PostHey Bug_racer maybe I might have to check out your theory of the injectors causing this ratlle. I replaced all the things in my previous thread and it still sounds like a bloody diesel on idle. Its actually embarrasing.Bug_racer supports the rebellion of the euro revolution
