Hey everyone, plan on going test drive a few GTI DSG this weekend. No clue about DSG's Any specific sounds I should be looking out for? Any particular actions I should perform to see whether the gear box is in good shape? The more information people can provide would will be very much appreciated !?! THANKS!!!
Checking condition of the DSG
Use it in all 3 modes, D S and Manual. The current owner might not like but you should rev the nuts off it and see what it changes like when you do that.
Must have had an oil change every 60K.
Should set off rolling, as soon as you come off the brakes, any lag in take off would be wrong. Might be able to stop that with a DSG reset with a VCDS cable, but you want that cleared before handing over your money. This sounds like you are slipping the clutch, you can feel the engine rev but the drive doesn't come in until much later. Makes parking a chore and hills starts a nightmare.
I'll echo Gavin's sentiments on the hill start.Originally posted by h100vw View PostUse it in all 3 modes, D S and Manual. The current owner might not like but you should rev the nuts off it and see what it changes like when you do that.
I would find the biggest hill you can and try accelerating on it from a stop.
This should show if the DSG has any faults.
I tested mine on the upramp of an underground carpark in the city. They are often very steep and will show up the problem Gavin has described.Originally posted by team_v View PostI would find the biggest hill you can and try accelerating on it from a stop.MY07 GOLF GTI
5-Door l Tornado Red l DSG l Leather l Xenons l MFD2 l TCP T.B.E l DNA stage 1
Car is parked on a slight declineOriginally posted by brimway View Post+1
Also reverse very slowly preferably up a slight incline. If it is not smooth, there maybe problems.
When starting the car and putting it into R, my GTI (2008, owned since new) does do a slight CLUNK because the clutch is engaging.
Had this checked out by the dealer a few times + spoke about it on the forum here. There is nothing wrong with this.
No, I mean like a slight "bunny hop" feeling. Hard to describe, but that was alerted me to my DSG problem in a MKV GTI. Ultimatele, the mechatronics was replaced under warranty.Originally posted by aDg3 View PostCar is parked on a slight decline
Oh ok, mine's more of a soft judder - don't think its major lol actually quite used to it. Doesn't happen as hard if the brake is applied properly before..ill re-test tonight.Originally posted by brimway View PostNo, I mean like a slight "bunny hop" feeling. Hard to describe, but that was alerted me to my DSG problem in a MKV GTI. Ultimatele, the mechatronics was replaced under warranty.
Judder is the word I was looking for. Mine started being very mild, barely noticeable but progressively got worse and then the false neutrals started.Originally posted by aDg3 View PostOh ok, mine's more of a soft judder - don't think its major lol actually quite used to it. Doesn't happen as hard if the brake is applied properly before..ill re-test tonight.
The two things Gavin has noted here - as soon as (well, within 50milliseconds maybe) you take your foot off the brake, do you have forward movement? And, when you go to accelerate do you get instant drive or does the engine rev likes it's in neutral for a second.Originally posted by aDg3 View PostWhat would happen to indicate there is fault?
I would also add to that, do you get a strong shudder when accelerating away as this can suggest a problem.
Originally posted by h100vw View PostShould set off rolling, as soon as you come off the brakes, any lag in take off would be wrong. Sounds like you are slipping the clutch, you can feel the engine rev but the drive doesn't come in until much later. Makes parking a chore and hills starts a nightmare.
GavinMY07 GOLF GTI
Paint that doesn't match.Originally posted by watevs View PostThis has nothing to do with the dsg. But I was wondering what to look out for to see whether the car has been in any major damage. ?
Paint tech is pretty good these days but still usually stands out if it has had some.
If you are concerned about this, get someone to inspect it for you.
does anyone know of anyone or company that can do that for me , around the CHATSWOOD area?
HOw come do they usually cost anyway?
thanks
