Steering Column Sensor issue
  • Steering Column Sensor issue
    We are having an ongoing saga with our 2006 MkV Golf.
    We had the windscreen replaced by a company (who won't be named). They fitted it, but the headlight/windscreen sensors wouldn't work.
    After a couple of phonecalls, they said, can you please disconnect the battery as this should reset the sensors, I knew it wouldn't, however I complied.
    Once we reconnected the battery, the sensors still weren't working AND now the amber steering warning light came on.
    The windscreen guys came and had a look and said they couldn't find any fault with the sensor connections, but arranged to take it to a local VW specialist (non dealership). The workshop found that they had bent some connector pins on the sensor. Easy fix, albeit long and drawn out, for the sensors.
    Now, we are struggling to get the PAS warning light to go. The workshop tried with their Rosstech VAGCOM, it didn't work, so today we dropped it off at Barloworld.
    Just received a phonecall saying the steering is fine and that it is the sensor in the steering column that needs replacing (Yaw sensor??)......$1200.
    Anyone know an easier/cheaper fix. Does the whole column have to be replaced or can the sensor be separated?
    Would disconnecting the battery be the cause of the problem? If it drops below a minimum voltage, does the sensor fry itself?
    the sensor loses its basic setting when voltage is lost. In rare cases it has been known that a steering angle sensor can fail from voltage loss.
      ^^ Spot on.
      Some require just a quick squirt up to 20klm/h with the steering wheel straight ahead. While others can't be revived.
      You're lucky it's not an MY09-onwards car. The sensor is in the rack, and can't be replaced separately.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        Just found the parts overseas (for $220 vs. $560 locally, both OEM parts). The procedure looks straight forward enough, I just need to get it calibrated after. Can I drive without calibration, or will that stuff it again?
          If you drive with it uncalibrated, you'll have no power assistance in the rack, as it doesn't know the end positions for the motor.
          '01 Beetle 2.0
