Urgent: Brake pad warning need advice now !!!
  • #16
    Originally posted by Diesel_vert View Post
    I have it on good authority that 14 mm is the thickness not including the backplate. Trust me
    Generally I would.
    Does your service person report the remaining friction material thickness at each service? Can you recall what it was?
    Mine was 9mm @ 15k; 8mm @ 30k; 7mm @ 45k; 6mm @ 60k (and quick visual through the wheels confirmed this to be correct). So unless the first 1/3 of the pad wears incredibly quickly then my best guess is that the pads are ~10mm.
    /thinks..... aren't these pads tapered or something weird like that?
    • #17
      I got the info from various VW technical documents floating around the web, one of which is http://vwts.ru/brake/g5/g5_46-01.pdf
      EDIT - Website doesn't approve of hotlinking, you'll have to copy and paste the link into your browser.
      Alternatively, just download as much as you need from http://vwts.ru/vw_golf5_1k.html
      EDIT 2 - found a better document - http://docs.jayzone.eu/erWin/VW/Golf...unning%20Gear/
      • #18
        Thanks. Interesting.
        If it's any help the fronts are 1849 & the rears might be 1865 (insert appropriate makers prefix)
        • #19
          Originally posted by Fatherless One View Post
          Hi all,
          This afternoon on the way home from work I had the "Check Brake Pads" warning, bloody typical, two days until Christmas and this happens.
          My question is: how long can I drive my car safely over the Christmas break?
          LOL, I cannot believe the coincidence!!!
          My check brake baps light came on the evening of Thursday 23rd... Just 3 days after it was at the mechanics looking into the damn racket coming from the secondary air intake.
          Just typical.
          Anyone know where I can take it to have the pads changed that won't attribute a debt comparable to that of the US financial situation? I am in RADelaide (Adelaide).
          Cheers,
          Simon.
          • #20
            Originally posted by mikinoz View Post
            No, you need to PANIC!
            Bump for added panic.
            • #21
              I had a brake warning come on after I reached 140kph. Not sure if speed had anything to do with it, as it never came on again. Rear pads needed changing after another 2000km though. So perhaps there's a bit of a buffer period build in.
              '03 1.8T AGU
              • #22
                LOL!!!! Panic in the streets of CBR tonight...
                MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
                T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
                • #23
                  If we're talking front pads, they are 14mm including the back plate, which is about 3mm.
                  I wouldn't worry if the light only just came on. You'll have plenty of time.
                  If they're fronts, get ready to be corn holed. Don't go original, talk to a pad supplier and get something else. Ferodo DS pads are good, and nowhere near as expensive as the originals - a little more aggressive with a bit less dust too.
                  • #24
                    Thanks for the info, what about disc/rotor suggestions?
                    I'm waiting for my mechanic to re-open, I wonder if he'll let me buy the parts and just have him fit them?
                    • #25
                      GSL RallySport, The Motor Sport Revolution!
                      Site sponsor.
                      Fixxxer
                      Lapiz Blue DSG Golf 7R
                      • #26
                        Easy. 328mm brembos and accompanying calipers. No more brake wear warning indicators to worry about either!
