Longest time between wheel alignments
  • #16
    RE: Longest time between wheel alignments
    The standard setting for the R 32 is +-0•7mm each and total of +-1•3mm As the flex is virtually non-existent with the superpro LCA, there is no forward aft movement with the LCAs. The net effect is the wheels don't toeout under brakes as with the original rubbers. I will watch it until the alloy knuckles and parts arrive. The pre adjustment was 6.0mm so it has to be better.
    Originally posted by Umai Naa!! View Post
    You'll find it'll need a small amount of toe-in, otherwise it'll trash the inner edges of the tyres.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    • #17
      Yes, that's true. In your case, I'd keep an eye on it for the time being.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
