Originally posted by kaanage
View Post
Mk V Whiteline Swaybar and ALK review
A sway bar does not add castor but our Anti lift kit does and what we were talking about.Originally posted by noone View PostCan you please elaborate on how a swaybar is adding castor?
It changes the position of the rear of the control arm and pushes the whee slightly forward hence adding castor
Thanks for the link to the paper - this would then explain why my car no longer dives into dips and hard turns with the ALK installed. The ALK does both jobs of anti-lift and anti-dive.Originally posted by kaanage View PostIs the effect of the ALK on the MkV to soften the anti-dive/anti-lift as delivered by VW?
That's what this paper says it does with the Subaru WRX in 2003.
If so, would the ALK alone, without the stiffer FSB, increase front roll (thus increasing front end grip)?
Edit: just seen that it does do all this on the Rennenhaus siteLast edited by triode12; 10-05-2011, 02:23 PM.
Do a search online. MRT in Sydney and Rennenhaus in Gosford are dealers and have online stores.Originally posted by thezoneR32 View PostSounds good, how much are they gonna cost me and will they work with my H&R sways?
The ALK works independent of the sways - i.e. you don't have to have WL sways installed.
*Update* Found this online:
http://www.onautos.com.au/epages/opa...roducts/KCA316.
$259Last edited by triode12; 10-05-2011, 02:43 PM.
Ah, got you.Originally posted by Whiteline View PostA sway bar does not add castor but our Anti lift kit does and what we were talking about.
It changes the position of the rear of the control arm and pushes the wheel slightly forward hence adding castor
We could use some more castor on the prior Polo GTI...
Actually, the ALK is REDUCING your anti-lift/dive so that your wheels can drop into dips through suspension droop rather than the whole car tipping into the dip. It should also make the car more compliant over sharp speed humps.Originally posted by triode12 View PostThanks for the link to the paper - this would then explain why my car no longer dives into dips and hard turns with the ALK installed. The ALK does both jobs of anti-lift and anti-dive.
As for the reduced movement in hard turns, that would be the anti roll bars, not the ALK at work.Resident grumpy old fart
Ah..thanks for clearing that up.Originally posted by kaanage View PostActually, the ALK is REDUCING your anti-lift/dive so that your wheels can drop into dips through suspension droop rather than the whole car tipping into the dip. It should also make the car more compliant over sharp speed humps.
