Own Servicing- Resetting service lights
  • Own Servicing- Resetting service lights
    For those that do your own services on your VW - how do you go about resetting your service code on the dash?
    I've seen a unit for sale at ECS that can do it
    Home Page > Search > ES9950 ES9951 > ES#9951 V-Checker Scanner - Basic - VAGCHECKERBASIC
    But is there any easier way?
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    The owner's manual could tell you how to. It varies from model to model.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      I'm pretty sure it's a fairly simple thing to do. Something like: with the ignition off press and hold the trip reset button then turn on ignition then release trip reset button and turn off ignition or something like that. I'm sure a search of the manual or the net will find the exact procedure. I did it once about 3 years ago so memory is a bit fuzzy.
        Key off, hold 0.0 button while turning the key on, "Service now" appears, release 0.0 button, then press the Min button. "Service now" will dissapear.
        To check, turn the key off, and back on again, and wait 5 seconds or so. If it doesn't re-appear, you've had success.
        Hope this helps.
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          Hope this helps.
          Cool! Thanks for that.
