start car without brake pedal engaged??
  • start car without brake pedal engaged??
    Hi all,
    I'm pretty sure that if you don't have the brake pedal pressed in, the car shouldn't allow you to start the engine???
    On my TDI, I can start the engine without my foot on the brake. I've also just realised that the cruise control doesn't work, which leaves me thinking that maybe there's an issue with some sort of switch that senses if the brake is engaged or not???
    I think that only works on Alfa with selespeed, or on Audi with smart key with push on start.
    Not on Golf with normal turnkey start as far as I know...
      Yes there is an issue with your brake pedal switch which explains the cruise control not working. I would take it into a vw dealer sooner rather then later..
      MKV GTI
        I know you can start the engine without the brake pedal pressed in the DSG (if you're in 'P' or 'N'), but you can't move the shifter until it's pressed.
        Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
          Oh okay...mine is the DSG, so maybe it is okay after all.......I can start the engine, but can't move it out of 'P' until I engage the brake.
          just have to work out why the cruise control doesn't work then.
            Might seem like a dumb question, but have you flicked the switch on the top edge of the left stalk so the cruise light comes on in the instrument cluster?
              yeah....tried flicking the switch on and off multiple times....no light comes on in the cluster.
              Reading around it seems that a faulty switch/stalk is fairly common...might have to get that looked at.
                Mine starts fine in P with no foot on the brake and my cruise control works fine. So your CC problem may be unrelated.
                The only fault I have in VCDS is rear-left door missing but my passengers assure me that it's there and the window works fine so I don't worry about it.
                MY07 Jetta TDI BKD DSG.
                  What does your manual tell you?
                  You mean the same switch that is used for the brake lights which is pretty easy to test, are you brake lights working or not?
                  website: www.my-gti.com
