Am pretty sure that the feature is only available to those with optioned parking sensors.
99% sure.
Correct. Only optioned from the factory, not later fitted by the dealer. Vagcom says memory seats (and maybe that's the case in some parts of the world) but it should read, "factory fitted reversing sensors".
Walker, great choice in colour for your jetta. I also read manuals (or the forums) when I go to bed. My Jetta works exactly like yours but my mates GTi (newer than mine) does not seem to have this feature.
Well I guess he should have bought a Jetta then
I like the little extras they provide standard in this model. The Platinum Grey is great and I'm glad we went with it in the end. It even matches the highlights in the standard wheels, which was a nice surprise. What did you get Thomas?
Oh ... good point ... my wife did adjust the mirrors yesteday, maybe it wasn't recentred. Shall check
I think you should try to set the mirror switch to LEFT position for the auto dip to work in reverse. If that doesn't fix it, then you should RE-SET the mirror dip - as someone might have adjusted the mirror after reversing (but not yet going forward) and that would have buggered up the auto functoin.
Dan
Hello guys im a newbie here and im pulling my hair out with this at the moment!!!
i have a 2006 vw golf mk5 gt tdi 140bhp
i bought a brand new passenger mirror 1K2857507BA which has the memory function built into it,also got a new door controller 1K0959702L Z04 which is a gen2 max controller so really this should work all the functions.
anyway i have the function on my highline to which i can switch on and off so that is working,but my problem is that when i put the switch to L and then put the car into reverse the mirror starts to move but it doesn't know when to stop also it goes all the way to the top sometimes out as well then i can set the mirror to the position i want for to see the kerb but then when i drive off the mirror just stays down all the time and doesn't move.it makes me think that either the door controller is not working correct for this function or well thats all i can think it is.
can anyone shed some light on this???
here are my 2 door controllers
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2444
Coding: 0000695
Shop #: WSC 01287 785 00200
VCID: 3753F89B3F25
No fault code found.
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Component: Tuer-SG 024 2468
Coding: 0000950
Shop #: WSC 00500 005 00500
VCID: 3851FBA7323B
