Punctured a tyre and needed to get it replaced.
Had Bridgestone Potenza RE001 225/45 R17 94W fitted to all 4 wheels previously...
They are no longer available in the 94 load rating and I've had the same Bridgestone RE001 225/45 R17 but in 91W fitted (so 1 different tyre only)...
Will this cause any problems?
As far as I can tell, the load difference means a slightly less stiff sidewall, but is it dangerous or should I be able to tell the difference.
Help much appreciated!
