GTI stock Air intake - am I missing a piece on mine?
  • GTI stock Air intake - am I missing a piece on mine?
    hi all
    was having a look at the air intake on my 2008 Golf GTI. Seems to have the 'bellows' all connected correctly, but directly underneath the bellows piece, there seems to be a gap that is about 25mm high with a divider in the middle. It would seem to allow air to come in under the intake and straight into the engine bay...
    Any idea what that gap is for? Or am I missing a piece?
    I will try to get a photo uploaded asap
    cheers
    S
    its normal. dont worry
      thanks Isaw
      that's a relief! Any idea why that gap is there?
      cheers
      S
        Post a pic...mine tends to spontaneously combust at the sight of a bump, probably the ****test thing on the whole car.
          here's a photo I just took. This is from inside the engine bay looking forwards. The gap is the dusty part with the red arrow pointing to it. It's approx 25mm high.
          please see this link: http://img835.imageshack.us/img835/6643/dsc00083b.jpg
          or if that doesn't work, perhaps try this link: http://yfrog.com/n7dsc00083bj
          thanks all
          cheers
          Satz
            Doesn't look like anything to worry about. Mine has the top cover above that slot come off regularly.
              Dont know what its for, but every mkv with the stock intake has it. never had a issue with mine, and neither has anyone else.
              /thread
                It's on the stock intake for the Tiguan as well.
                I believe it has something to do with allowing dust and other particulates flow out through the air box and not clog up the airfilter.
                However, it also allows the car to suck in hot air from teh engine bay when under load which drops power.
                The APR carbonio is enclosed and only allows the cold air form the front to enter the intake which remedies this problem.
                  On my R32 I cut the sides with a knife and bent the flap down to reduce hot air into intake.
                  Im guessing I benefit from more cold air in too
                  Bazzle
                  Prev 2008 R32 3 door DSG.
                  Now Lexus IS350 F Sport
                    A bit OT but any opinions on the best after market set up these days?
                      Thanks guys
                      at least mine seems to be 'normal'! Does look like a slightly inefficient intake, in that it is offset from the airflow, so might lose a bit of ram-air effect. However I have faith in VW engineers that there is a reason for this design!
                      Coming from a Mazda CX7 turbo in which I tried the many DIY mods for intakes and exhaust (all of which compromised the car in some way)....I think I'll leave the GTI stock
                      ...for now
                        Originally posted by satz View Post
                        thanks Isaw
                        cheers
                        S
                        I presume it's to minimise the amount of water going into the intake. You'd notice that the pipe going into the intake/engine is higher than the opening at the front (grill side).
