GTi ECU reprograming recall
  • #16
    As stated in the original heading, GTi only.
    Andrew
    • #17
      Just had a call from one of our EOS customers - looks like it applies to the EOS 2.0T as well (well some of them anyway!)
      • #18
        Yep, I got the same letter for my 06 Jetta TFSI with DSG. I'll book in to get it done and then back to Guy to redo the APR.
        Scirocco R | DSG | 19" Talladegas | Viper Green
        MkVI Golf 118TSI | 6spd Man | 17" Classixs | APR Stage I
        MkV Jetta 2.0 TFSI | DSG | 18" Charlestons | APR Stage II
        • #19
          Did the recall today, but only drove home - nothing noticeable, but I was never chipped.
          • #20
            [QUOTE=gtimk5;57448]As stated in the original heading, GTi only.
            Andrew [/QUOTE
            Maybe OP thought it was for GTI only not aware that it could be particular software design
            GOLF V 2.0 TDI COMFORTLINE
            SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
            • #21
              It appears to be for all the 2litre turbos.
              Mine goes in at 1 today, getting the golf GT while they do it.
              I will post on results later, though I will have to do a reflash this arvo, time permitting! (and internet problems allowing!!!)
              Cheers, Andrew
              • #22
                golf gt!!! lucky bugger andrew!! make sure you give it a good "test"!!!!
                • #23
                  Yep! Be able to report back on my thoughts.
                  I have heard a couple of dissapointing things on them, but will keep my mind clear.
                  Cheers, Andrew
                  • #24
                    Recall
                    All car makers these days do programme updates from time to time,just the same as anything running electronics gets periodical updates.What about Windows computer updates they come thru regularly. Its purly an update its not like them retuning the performance or anything. & all car makers do this on services. Thats why to maintain your car in top running order you MUST get dealer serviced!!! ....Bazz ...&.. (No I dont work for VW,Iam retired!)
                    • #25
                      Well, had my GTi done this afternoon and it took them about an hour. I get on well with the dealer here and they lent me a Golf GT with DSG. Great car, went well and has the great Mk5 chassis.
                      As for the warranty, everything went without a hiccup and I reflashed it this afternoon.
                      Cheers, Andrew
                      • #26
                        so guys,,lets just clarify something with this update...
                        Tinys problem with his oettinger chip was because of this VW software problem..?? right??
                        Wish there was someone in WA switched on like this. Local VW dealer hadn't even heard of LC until IU asked, then he went out and tested an R32. You'd think these guys would know it existed. I took mine for a run down country on the weekend, and while cruising at 110 it had a slight hesitation...
                        did the oettinger guys know that it was a VW software problem??
                        andrew,,,compared to the tdi?? how did the gt go??
                        • #27
                          Not sure GPK whether anyone knew VW had the problem.
                          They talk down the recall thing saying its just to stop a bogus code from coming up but last night, with my car after reflashing it. WOW! Huge difference!
                          Much better power delivery, heaps more torque and revs out better. No, it wasnt a cool night either, bout 16 degrees on the way home.
                          Cheers, Andrew
                          • #28
                            There's info on the recalls (same as here / US & Germany) :
                            Speaking to Oettinger last night, Germany is having to reflash all cars as well
                            "The software version of the is specific to the particular control module part number. These are the current software versions for the 2.0T FSI engines sold in the US, keep in mind that there are different ECU part number and software versions for the rest of the world and non-listed models/brands (i.e. Audi A6 (4F) and Skoda Octavia (1Z)).
                            Audi A3 (8P):
                            8P0-907-115-B @ 0070
                            8P0-907-115-G @ 0040
                            Audi A4 (8E):
                            8E1-910-115 @ 0030
                            VW Golf/Jetta (1K):
                            1K0-907-115-B @ 0030
                            1K0-907-115-H @ 0030
                            VW Eos (1F):
                            1Q0-907-115-B > 1Q0-907-115-D @ 0030 (software part number changes!)
                            VW Passat (3C):
                            3C0-907-115-F @ 0020
                            3C0-907-115-G > 3C0-907-115-F @ 0020 (software part number changes!)
                            3C0-907-115-P @ 0030
                            Solved Problems with 2.0T software updates:
                            - Internal control module checksum errors
                            - Oil sedimentation at low temperatures and short distance driving
                            - Cold start issues
                            - Rough running in certain load levels
                            - Several fault codes caused by inappropriate software setup
                            - ...and other...
                            • #29
                              Still waiting for my letter... wonder if it's particular year models that are affected??
                              • #30
                                I have an Eos and also received a letter and will take it in next week!
