Sorry but bear with me here.
I have a 08 GTI manual. Done 42000 kms.
Up until about a week ago not one problem with it .. and I am not sure even if this is a problem.
On coming to a stop and leaving my foot on the clutch with the gear engaged, I will usually get a vibration coming up through my foot. It seems as if something spinning is making contact with something in the gearbox and coming to a halt.
If I do not have it in gear then the problem does not appear to occur. If I take off and come to a stop again (with my foot on the clutch) then the same thing. If I take it out of gear and put my foot on the clucth again .. nothing happens.
So it appears to be when coming to a stop after it has been in gear and leaving my foot on the clutch without disengaging the gear will produce this vibration.
Finally I can engage the clutch a bit without moving and push it back to the floor and I can also get the vibration.
I originally thought it might be my foot shifting slightly on the clutch, however have discounted that due to some rigourous testing of the problem. The vibration is nothing soul wrenching, but is certainly out of the norm.
Any ideas? Sorry about the essay, but thought I should include as much info as possible. By the way there is nothign you can catually "hear" .. it is simply the vibration coming up from the clutch pedal to my foot.
One other thing .. I read somewhere that you can get the sunglass holder replaced under warranty .. as I am going in for my 45K service soon does anyone have a warranty number or similar in case they try to fob me off?
Thanks
Thanks
