Hello all, i have the Engine check light on so i took it to an auto electrician who has a Vag com. he found the following code 16825 P0441. i have looked the code up on the Ross Tech site and this is the breakdown.
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
where can i find the Canister Purge Solenoid Valve? is this circled in red?
Fastest
Possible Symptoms
Possible Causes
Possible Solutions
Perform Output Test
Fastest
