Lowered suspension
  • Lowered suspension
    I own a 2008 jetta tdi is there anyone who can help me with some information on sports suspension for my car. I run 18 inch Passat alloys and would like to lower the car by + - 15 to 20 mm.
    Paul
    Do you want to change the shocks as well? or just lower it with lowering springs?
    For springs H&R or Eibach are one of the better springs to get if you are just looking at springs. Neuspeed have a set with Koni FSD shocks.
    I went for HPA KW SHS coilovers (available for Jettas also) which tend to keep the comfort of the stock setup allowing you to lower the car with a bit of extra performance.
    Have a look at this thread, has different types of suspension, a good starting point. Not sure whether they will match the Jetta though.
    A compilation of White James Suspension & Wheel Reviews: Products: KW H&R Eibach Koni Bilstein Tein Nuespeed Whiteline Sachs Ohlins Volkswagen OEM geniune Driver Gear Sport Springs Items: Coilovers Sway Bars Strut Springs Dampers Common Problems/Issues Identified with MKV and MK6...
      15mm drop, i would go H&R springs.
      GTI_Dave stocks them.
      He is loated in Victoria too.
        Thanks for the info.Ihave already looked at H&R but there springs lower the car by 30mm i am not to sure if this will be to much.
        Thanks again
        Paul
          Hmmm the shortest they will go is 30mm, that is annoying.
          Might have to invest in some oem GTI springs or similar.
            VW Fanatic
            Do you know where i could get some GTI or JETTA ( turbo petrol ) springs from.
            cheers
            Paul
              MKv golf GTI/JETTA (tsi) springs
              Hi Fanatics can anyone help me with finding some springs from a MKv golf gti or jetta (tsi)
              Paul
                did u try looking in the for sale section?
                FOLLOW US ON FACEBOOK
                  I've lowered my car on Eibachs I believe and the drop was 30mm. Looks great and I get no scrubbin at all
                    When'd you do that?
                      Originally posted by GTom View Post
                      When'd you do that?
                      Same day as that epic dust storm. My car was left outside at the mechanics all day and came back to me orange
                        Is the 30mm quoted based on the US or Aus/Eurocar height?
                        With American cars looking like 4x4 in stock form it wouldn't surprise me.
                        I'd expect the drop to be less than 30 if you're buying a kit that was intended for the US market (isn't eibach American?)
                        my pirelli is down 22mm from it's stock height and will occasionally rub.
