VagCom (VCDS) codings
  • VagCom (VCDS) codings
    Enabling headlight lamp in Instrument cluster
    Audi A4 B7
    Go to the Instrument Cluster module (17)
    Make a note of the coding
    -2 form the coding in the ?? part - 00??xxx
    Mine was 0006411 , recoded to 0004411 and voila the instrument cluster sidelight lamp lights up.
    __________________________________________________ _______________________________________
    Ahh .. heres the one I was looking for for the "Enabling headlight lamp in Instrument cluster" a few months back.
    I will try it tonight..
    Might not work on the Golf though.
    Bazzle
    Prev 2008 R32 3 door DSG.
    Now Lexus IS350 F Sport
    Top level desc.
    Bazzle
      So have you tried it? I'm not sure what it actually does? haha
        OT: In the MKV golfs is it possible to somehow add a second reverse light on the right hand side. It's too annoying when people say "your reverse light is out" and it is quite dark when reversing.
        Genuine VW Parts Importer | Navigation | Bluetooth |
        Repairs | Lighting | Coding | Programming |Cameras
          it is possible to code for two reverse lights, but you would still need to remove the red lens from the fog light.
          Jason.
          05 Golf 1.9 TDI comfortline DSG
            Jason.
            Any guides available?
              not that im aware of, but it's one of the things i came across when i had the new gateway fitted.
              there is an option that says "2 reverse lights fitted" and in effect turns the fog into a reverse light.
              if you have the VCDS software, it shouldn't be too hard to find.
                DeanCorp probably meant how to remove/make from red lens white one. Most likely you will have to buy a new tail light for left hand drive car. Otherwise selecting 2 reverse light option in VCDS is as easy as ticking the box in VCDS software.
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                  Didn't someone like Polar do this about two months back. didn't seem overly hard from memory....just removed the red lens, and ended up with one a bit brighter but it worked fine!
                    polar didn't use VCDS. he just piggy backed a power line to the other side.
                    different solution, same result.
                    Jason
                      Hmm... that didnt work, IK chassis must be different.
                      I dont think there is even an Ind in cluster.
                      Bazzle
                        Is there anyone on here who can do the VCDS coding for 2 reverse lights for me? I would be grateful. A token of appreciation will be provided
                        2009 R32 - Reflex silver- DSG, Sunroof, RNS-510, Kufatec Bluetooth, Flapper mod
                        2008 Polo GTI - Black magic - Leather - Seat Cupra R bushes
