I never said I don't remove them.
60,000KM Service Mk V 2.0 Diesel DSG
So you will loose all your coolant to "check the pump" which i have found 90% are cracked between the shaft and impellar, its a known issue, so its removed why not spend an extra $90 and fit one with a metal impellar, you have removed the 3 bolts to check it and loose all your coolant, i dont get it mate sorry, only trying to help, i do this for a living
JmacAlba European
I know where you're coming from, I do it for a living, too. Unfortunately, I'm not the one that pays the bill. As for the coolant loss, it's minimal, and is re-used. Probably only adds 15mins to the job.
If it were up to me, I'd be putting a water pump in when the timing belt is replaced. But, I can't play by my rules (yet). Hell, I couldn't even get VW to cover a water pump in a Tiguan that cooked itself.'07 Transporter 1.9 TDI
'01 Beetle 2.0
Thats right, but the water pump is in the heart of the engine, you lose loads of coolant. i wouldnt reuse either at the minimum cost to replenish anyway, not to worry, when you play by your rules itll change
Sad story about the Tig too, that sux.
JmacAlba European
The oil is under $160 retail for the six litres required (could be five litres without the mechatronics but allow six).Originally posted by GTI_racer View PostThe 60k one is a big one which involves among other things a DSG flush.
the oil is like $50 per litre and you need 5 litres.
then there is the replacing of a lot of filters as well
The transmission filter is under $65 retail.
The transmission filter seal is under $4 retail.
Labour is 2 hours so around $220.
You should pay between $400 and $500 for the dsg service.
Some details of the bits used are here (plus some extra bits)
Volkswagen DSG Mechatronic Replacement
website: www.my-gti.com
It's listed in the handbooks, service books and service schedules!Originally posted by Umai Naa!! View PostUh huh. VW told me the same thing, so I'm calling them tomorrow, to find out for sure.
It's one more thing we can sting the customer for
We're running off 4 different VW-supplied service schedules right now. Not a lot seems to line up! Personally, I stick with what the book says, but the upper management prefers other methods. I seriously can't winOriginally posted by Maverick View PostIt's listed in the handbooks, service books and service schedules!
'01 Beetle 2.0
Stick with what makes you the most money and over serviceOriginally posted by Umai Naa!! View PostWe're running off 4 different VW-supplied service schedules right now. Not a lot seems to line up! Personally, I stick with what the book says, but the upper management prefers other methods. I seriously can't win
Oh yeah if you have a PD 2.0 or 1.9 PD then its timing belt , guides and the tensioners and without doubt the water pump ( 3 extra bolts to remove), if you are in that far its a no brainer. Coupled with the DSG itll be on its second filter and oil service too.Originally posted by TDiJetta09 View PostI was told around $900 from my local VW service centre for the 60k service. They do a flush and filters on the DSG. It's the 120K service that is going to empty the bank account!!
JmacAlba European
I lusted after a GT TDI - great torque, great mileage with DSG all round a near GTI (Sigh) however small euro diesel engines not that reliable when old and expensive to fix, turbochargers commonly fail early and never last the life of the engine. and DSG, well I can wear the extra charges service over a manual but reliability??? Mechatronix Module - all you DSG fans come on I dare you to quote one less than in the thousands. Dual clutch replacement - I shudder.
VW I love the ride performance style etc.... really, really do (also have a thing for MINI) but they do not last
I have a car which was not particularly reliable but very satisfying and simple, a MK1 GTI which one day I will put back on the road,
now driving a MX5 (dont laugh, third most reliable car of the decade)Golf Cabrio GTI
