hi all, just quick question. can rcd500 direct plug and play on 05 golf?my rcd300 is broke and just need to find one that can direct replace. any other model can fit too. thanks
of course the units will physically fit, but as you should be aware, swapping from an older unit to the newer ones CAN lead to the battery drain issue.
that's why i said stick to the same series unit and it should be ok.
i cant drive yet.(have not been given clearance from my Dr yet)
Jason.
Edit:
send me a PM if you want the unit and ill give you details of my address and what times are good.
it's wrapped in the bubble wrap that my RCD510 came in.
i have the book and the code too.
