I've posted this in the problems register but now I'm interested to see if there's a smple explanation for this:
1. When I turn the car off, the radio is supposed to stay on until I remove the key right? Well sometimes the radio cuts out immediately. Sometimes, I leave the key in the ignition after I turn the car off (with the window down) at home and the radio will sponateously come on about 15mins after turning the car off..
2. I have the automatic door lock activated. Sometimes when I drive over the set speed, the doors will lock then unlock immediately. Sometimes doing a rapid lock/unlock cycle. At this point I will usually hear a faint chattering sound coming from the dash just behind the steering wheel.. To solve the lock/unlock problem, I usually have to pull over/stop the car and press the unlock button. Then they will behave normally.
And finally; 3. Tonight when I turned the car off, the interior courtesy lights wouldn't come on. I tried it 3 times and gave up..
Thanks!
Thanks!
