General Lights Discussion
  • #16
    i will head down to the garage now, and see what i can do.
    though it wont be completely dark, as the underground lighting will be on....
    Jason.
    05 Golf 1.9 TDI comfortline DSG
    • #17
      here is the best i could do.
      as i said, once the halogens are on, the leds don't show up on camera too well.
      though they are very noticeable to the eye (on low beam) once high beam is on, not that noticeable.
      here goes...
      in order...
      parkers only
      low beam
      high beam (showing off my new spotties)
      the camera just can't capture the true look of the lights.
      i will see if they show up any better on video (tomorrow)
      Jason.
      • #18
        Originally posted by 85turbo View Post
        yeah, Maca it was a pain to get them out.
        if i were you, i would get a set of these LED's, as any halogen (incandescent) globe will look very yellow next to HID lighting.
        i plan on changing to HID later (once i get a set of projector lights).
        i have Narva Blue Power H7's fitted now, and they are heaps whiter than the stock globes.
        the old stock parkers were very yellow. now i have the led parkers installed, the Narva's now look yellow in comparison.
        so i guess i know what my Xmas bonus is going on..... (HID)
        Jason.
        When I say Xenon-Look.. I mean that the cluster looks like the Xenon's on the R32's etc.. The bulbs will be Halogen unfortunately..
        Originally posted by Thor Ray View Post
        Mate, I have about 3 pairs of them that I'll not use now with the dynabeams and the Celis light
        Do you want them, Im happy to send them to you if so, PM your address,
        Cheers!!
        I may just take you up on that offer.. I will however wait until I get the new lights as I may take the plunge and go for orange park lights (to blend in with the indicator when it's on)..
        Jason.
        You probs won't get a good photo of the actual bulbs unless if it's daylight.. It'll be good to see them!!
        • #19
          yeah i've tried these on a bora couple of weeks back, but found them too bright and too white comparing to my lights. so now i went for some blue vision parkers.
          '01 VW Bora V6 4motion - gone
          17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
          • #20
            ill go get a few pics tonight....
            how much were your dynabeams ?
            i really want a set of those....
            where did you get them from, and are they the correct beam pattern for RHD cars ?
            Jason.
            DynaBeams are available on the TM Tuning website along with a few other light styles. I've found that their prices aren't all that expensive depending on what you go for..
            • #21
              what is VCDS for us noobs? and how do u disable that startup thingy with it?
              • #22
                Ordered.
                Should look better with them in my projectors. The parker light there is much better than up in the high beam.
                • #23
                  Hook me up yevvy!
                  • #24
                    Why did you get those ones?
                    Wouldn't a 6 LED focused white be better than that?
                    The 26 LED configuration is great for foot wells as it spreads the light (and you can't see it)...but looks ugly.
                    Not having a go, just curious
                    Ze A4 Projekt 1.8T Quattro - 79.3 KW at the wheels and climbing =P
                    Check it out at the epcc.net.au circuit events
                    • #25
                      Jason.
                      Hi Man,
                      I go everything from http://www.tmtuning.com/vw/ really good, the delivery takes about two weeks,
                      How much: about $850, and yes they have for RHD cars,
                      Cheers!
                      .:Polo 6R 77TSI
                      .:Golf MK6 GTI
                      II Kraftwerk
                      • #26
                        it's the Volkswagen Communication and Diagnostic Software.
                        with it, you can "fiddle about" with a great many things in the car....
                        i don't think so. the fewer the number of leds, the less even the spread of light would be.
                        Hi Man,
                        thanks.
                        looks like i know what my xmas bonus is going on.....
                        Jason.
                        • #27
                          Where can one get the VCDS and how do u work it? Install on laptop and plug in?
                          • #28
                            VAG-COM is what you're looking for, have a bit of a search.
                            • #29
                              VAG-COM is the same as VCDS...
                              anyhoo....
                              Ross-tech
                              and here is the cable that you probably want.....
                              Cable
                              the software itself is free. to use it, you will need the cable.
                              entry level cable (that only suits the mk5 platform) start at $249 US + delivery.
                              it's on my shopping list.
                              Jason.
                              • #30
                                Alright. So my GTI's dome lights are now all LED using the following in Pure White: I have these in all 5 overhead lights; the center festoon between the maps lights [2006 MY FTW] was removed. Now onto the issue. When I leave the lighting setting on 'door', the LEDs don't go out...
                                BLESK, same look as mine from JWarden above.
                                I discovered the Blesk / Maxlux LEDs when some VW owners in Europe posted about them - Brex buddy got them for me. Use two of these in the license lights - total $26 shipped in US - Plug and play - no resistor needed - simple bulb swap ... The packaging is labeled Blesk, the bulb is labeled...
                                Bazzle
                                Prev 2008 R32 3 door DSG.
                                Now Lexus IS350 F Sport
