I just got 25K km on Goodyear EXCELLENCE and they are due for replacement. I always had them balanced and alignments done by Goodyear shop according to their book. This is very poor result as the original NCT5 lasted 45K km. I am after everyday tyres that would last. What would be your advice? Thanks.
195/65R15 tyres
Well the original tyres lasted 45K km. I would go for the same unless I know what tyre will last longer.Originally posted by HiTorque View PostI just got 25K km on Goodyear EXCELLENCE and they are due for replacement. I always had them balanced and alignments done by Goodyear shop according to their book. This is very poor result as the original NCT5 lasted 45K km. I am after everyday tyres that would last. What would be your advice? Thanks.
From my experience generally Pirelli tyres are long lasting tyres in all sizes.
I use Hankook on my van and I like them (replacement for Michelin Pilot Premacy - only lasted 25K km).
Tell tyre fitter that you want a quiet that will last.
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
I found it;
A golf IV got 90kms out of them. Perhaps you need to adjust your driving style.
MarisLast edited by WEDEL.1; 31-07-2009, 10:09 PM.sigpic
I'd suggest less throttle input.
Actually, I just checked our Golf and... yes we have GY eagle NCT5 as well, so far done 21,000km and they look like new.
But I have to be honest; there was a small problem with the tyres right from the new. Two from four were oval not circle shape and caused a nasty vibration I could feel in the center of the car and also in the seat. Good Year replaced tyres and all was good.
They are made in South Africa and I was decided not to buy them again when they wear out but reading the comments in that link above (thanks for posting it), I’ve changed my mind now.
Goodyear don't list their treadwear ratings on their Australian website but in the USA they are TWR 700Originally posted by HiTorque View PostI just got 25K km on Goodyear EXCELLENCE and they are due for replacement. I always had them balanced and alignments done by Goodyear shop according to their book. This is very poor result as the original NCT5 lasted 45K km. I am after everyday tyres that would last. What would be your advice? Thanks.
This is a really hard tyre! The NCT5 is TWR 240 which is a fraction soft.
If you are wearing out TWR700 tyres in 25,000km then my guess is the tyres aren't coping with your driving style & vehicle & they are getting lots of slip. Slip causes tyres to wear.
Maybe rather than telling the tyre people you want the longest wearing tyre possible, which in their mind means hardest compound available, you should explain how you drive & what mileage you get out of certain tyres. Then they can recommend something appropriate.
Even going back to NCT5 might not be an option because sometimes OEM tyres are a different spec to what is sold retail.
If it was me, I'd look at the following:
Continental ContiProContact
Michelin Energy XM1+
Yokohama C-Drive
Kumho KH15 Solus
But it could be the tyre & rim package you have just doesn't suit your right foot.
What about these 16" rims with slightly wider tyres for $400? pretty cheap & the tyres look like they have a little life left in them. Then you can fit a better quality 205/55x16 to the rims.carandimage The place where Off-Topic is On-Topic
An interesting review from the same web site on the Excellence. This suggests that they do not last, but may be more handling orientated.
I don't usually push tyres to their limits and perhaps drove less enthusiastically then on the first set. I guess it's cheap asian of african import.Originally posted by WEDEL.1 View PostAn interesting review from the same web site on the Excellence. This suggests that they do not last, but may be more handling orientated.
http://www.productreview.com.au/show...?item_id=160302005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
HiTorque
I have the same car. The original tyres had the same problems as yours.
Not round and only lasted 45k.
Its a heavy car up front the TDI.
If you put on a soft compound, it'll wear out, simple as that.
Currently have on the car Yokohama C-Drives.
Quiet, just as grippy and seems to be lasting just as long.
Regards,
David
Good point. I run 34 psi allround the Golf 5 (195/65 X 15) and rotate every 10kms.Originally posted by Umai Naa!! View PostOne of the things I've noticed with our customers' cars, is the rediculously low tyre pressures people run in them. I don't know what you guys are running them at, but I set them at 36psi. Also, rotating them every 15,000klms does wonders.
Marissigpic
Ha Ha Maris!!!
I think Mav is saying that if you swap your wheels every 10 kms you should leave this week if you are planning to drive to the DOVW in november!!!
34 psi is what I set most of my customers Mk5 15in tyres at by the wayLast edited by gtimk5; 04-08-2009, 08:56 PM.Par 6 Golf GTI. Coilovers, BBS CH Wheels, APR'd
