Originally posted by 85turbo
View Post
Front Wiper Blades
Originally posted by 85turbo View Posti got complete replacement blades from Trico.
got them from my local PEP auto store in Sydney.
cost about $45 for both front blades. fitted in about 30 seconds.
easy. when i get home next week, i can post the part numbers if you wish.
note, these are complete replacement units, not just the rubber inserts.
and they work great.
Jason.
Please post the info for others .
Thanks BazzlePrev 2008 R32 3 door DSG.
Prev 2010 S3 Sportback Stronic.
Now Lexus IS350 F Sport
Originally posted by No457 Snowy View PostGuys, all the pics have been re-done and text has been updated in the how-to. For the MKV I would actually buy two sets of the rubbers and use a rubber from the second set to extend the length at the bottom of the drivers side wiper for this and subsequent wiper changes. (the how-to was for a MK4 and the MK5 Aero Wiper on the drivers side is a little longer I believe).
updated wiper DIY
Snowy.
Purchase 2 x wiper blade inserts from a reputable VW dealer in SE Melbourne today.
Cost $16.94 ea inc GST
Length 700mm so cut to size
Genuine VW part no. is 1K0955429A and includes a new end clip so if you damage the clip getting it off you have a replacement new one.
The German printing has 'Wischgummi 1 Stueck' for the translators out there.
The package has an expiry date of 2012/01 and package date 12.01.09 so three years life!
Made in Belgium.
Also has the Audi, Skoda, VW and SEAT symbols printed on the label. (if I new how to use the wife's camera I'd try and send a pic).
It's nice to have clear view again!
And PS the instructions on the thread are very good,
Cheers,
NeilBeigeJet
White MY23 Tiguan 147 TDI Elegance (mine)
White MY21 Tiguan 147 TDI Elegance (wife)
Gone - Wheat Beige MY07 Jetta TDI manual
Cheers,
Neil
I haven't replace the rear yet, It hardly gets used so it's not too bad. Anyone know the part number for the rear rubber?
Originally posted by EUS GTIMK5 View PostAnyone know the part number for the rear rubber?
i replaced my rear blade assembly today...
genuine VW part # 6Q6 955 425 A $21.50.
also, regarding my earlier post about the front assemblies.
they are Tridon, NOT Trico as i stated.
part numbers are TFB19SL and TFB24SL these were a direct replacement.
fit in about 30 seconds. cost about $45 for the pair.
Jason.05 Golf 1.9 TDI comfortline DSG
I have just changed mine, but I bought Aunge type rubber refill.
What I noticed is difference at the top of the blade. VW refill has wide top, while Aunge has a narrow one. I hope they won't slip out.
And yes I believe VW are charging way too much for front and rear.
Plastic ends were a little bit difficult to take off but not much. While the shorter blade went on fine without any problems, longer one has given a lot resistance, probably because of it's length. It kept on slipping out numerous time... The further I went up , more she came out.
But at the end I prevailed.
Haven't tested yet, just cleaned my car, but I will tomorrow morning when I wipe off dust collected overnight.
Edit 20.10.2009
Wipers tested... Work like new and rubber stays inside.. $4.50....
Edit 27.10.09
After a hot day today wiper inserts are coming out..... Looks like it is time for Tridon onesLast edited by acdcfan; 27-10-2009, 07:24 PM.GOLF V 2.0 TDI COMFORTLINE
SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
Originally posted by VOLKSMAN View Postnothing beats factory vw, sure is expensive but damn its worth it!!!GOLF V 2.0 TDI COMFORTLINE
Made in Belgium.
Cheers,
Neil
It would be good if you could have posted the picture for every one to see
Edit
Is this for golf MkV?Last edited by acdcfan; 26-10-2009, 08:52 PM.GOLF V 2.0 TDI COMFORTLINE
A word of warning for the diy'ers.
I bought a Daihatsu years ago (...desperate times), and noticed an arc on the drivers side of the front windscreen which had been polished out... mostly. I dont know how they managed to get a rwc for it.
Anyway, I ended up having to replace the screen for a rwc, which was good as it was so distracting. The arc was caused by the previous owner replacing the front blades with some that were slightly narrower. End result was the wiper arm clip worked loose from the blade and must have been scraping back and forth across the windscreen for quite a while before they actually did anything about it. The fix was pretty agricultural, crush the carrier together over the wiper rubber...
In no way i am i recommending paying the crazy price for a workshop replacement, just be very careful with replacement wiper blades! if it isnt identical in profile, i wouldnt use it.MY07 R32, black, DSG, 3dr, sunroof
02GT Forester
Did anyone changed rear wiper blade?
If so, how did you do it?GOLF V 2.0 TDI COMFORTLINE
Yes there is the cheaper option of just rubbers with new end cap but is not NOT listed for most models hence why they are quoting you a whole aero blade. if they were smart they would keep this part in mind when quoting wipers as it generally suits most models.
I don't see how $100 is a rip off for 3 oem wiper blades. I would happily pay that for piece of mind in knowing I have the best possible wiper blades for my car. It's 33 per blade, hardly worth wasting a Saturday morning at superchip autoMKV GTI
