Got the Golf seviced a while ago and they said wipers needed replacing. Quoted $105!!!! for all three.
Finally got around to changing the rubber. You don't have to buy the complete assembly.
Just remove the end cap (I used a screwdriver) from the end where the rubber blade does not move. This is the end that has a retaining hook holding the rubber blade in place. Then bend the restraining hook up and slide the old rubber blade out. Insert new blade, bend hook back and re-fit end cap.
First one took a while as the rubber was a tight fit. Second one took about 5 mins. Note they are different sizes, just cut to fit.
New rubber blades cost $12.79 at Repco, saved a packet! Got Trico TTR610 (i.e. 610mm) just get rid of the fittings, only need the rubber.
Sorry no pics as camera stuffed.
I thought I remember reading a write up of this somewhere but I cannot find it now?
. It seems the Trico refill and Aunger refill cross section is a little thicker on the bit of rubber retaining the refill to the blade AND I cannot get the thing slid into the blade any more than about 100mm without forcing it. I don't want bend it the wrong way.
