Hi Folks
I'm having some issues with boost lately. I have APR stage 1 and when things were running well I would hit 20 psi +/- 1psi and it would taper off to around 15 under wot.
Lately I'm lucky if I can hit 10 psi.
Today I visited my local workshop (Volkspower) and had the new psiton type D diverted valve (the type G I had from a previous leak was still in tact ) and we also installed and the BSH PCV fix....still not fixed. They also ran a VAGCOM and got no errors reported. The car is still revving hard but not the kick in the pants feel it should have.
I also have a newsouth gauge so can monitor the boost in different gears. Is it possible the connection between the gauge fitting and the boost line could cause the issue ?
...trying to work out what it is - I'm no mechanic so need all the help i can get.
...basically he car feels way underpowered to what it has been when everything was working as it should. I'd like to think it was just me getting used to all the TFSi power
but it isn't.
I'll be fitting the APR RSC TBE (acronym city) and HPFP soon but wanted to sort this out first.
Thanks in anticipation of some wisdom
but it isn't.I'll be fitting the APR RSC TBE (acronym city) and HPFP soon but wanted to sort this out first.
