Hi All.
Well after the Tune, Full Exhaust and 328mm brembos, the KW V3s went on today.
The doods who fitted it set it up to KW's factory spec, and they set the ride height about 20mm lower than the standard pirelli (which is itself a bit lower than a standard GTI). You can just squeeze your hand in between the guard and the top of the tyre - which is good, I didn't want it stupidly low.
Ride is firm - not hard. The nose barely dips under very heavy braking, and it goes around corners like it's on rails.
I've not had a chance to properly test it out, but will tomorrow on the Pirelli's first track day!
Will post some pics later....
Have fun at the track tomorrow!
