How does the R32 compare to the GTI in fuel consumption? Is it heaps more in real life?
R32 and GTI fuel usage?
Depends on your driving but you will spend up to 50% more on fuel. But the R32 is $10K more then the GTI, who really cares about fuel consumption (within reason) when you're spending that much. You want to save money on fuel buy a tractor, the GT TDI fits the bill and you can use it to mow the grass.Originally posted by airofu View PostHow does the R32 compare to the GTI in fuel consumption? Is it heaps more in real life?website: www.my-gti.com
My 07 gti, DSG, no mods does the following:
Highway driving: 7.5 - 8.5 kms/100l
City driving: 9.0 - 10.5 kms/100l
"S mode driving: 10.00 - 15.0 kms/100l depending on how long I rag it for.
MY10 R, DSG, Recaros, ACC, Dynaudio, MDI, Stage 2 APR, CAI, APR HPFP
It's a 200kg heavier car, it has a 6 cylinder and it's AWD, officially it uses ~20% more but it depends on how you drive it. Why worry about fuel though if you're spending $50K+?Originally posted by airofu View Post50% more...is it that huge?
I know the R32 will be more just curious in real life figures as an average...
If you do 10,000km a year and the difference between two cars is 10l per 100km and 15l per 100km this is $650 per year in fuel.
1000 litres x $1.30 = $1300
1500 litres x $1.30 = $1950
There are too many factors to say what an average is, if you chip either car they will use more fuel and it really does come down to how you drive, what gearbox you choose and where you drive and when.website: www.my-gti.com
But seriously - how could you own a car like the GTI or R32 and have good fuel economy? Haha2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
My MK4 R32 uses about 11.5 to 12L normal driving and im rarely on a freeway. CAI helped a lot, consumption went down almost a litre.
If we have a crise things change dramatically, it goes up to 15-16L/100km but thats not that often so its ok. Its not as bad as it seems1991 BMW 318is RED E30
at the moment my GTI is doing nothing but stop start peak hour traffic both to and from work during the week and on the weekend its still urban but its getting flogged. as a result my consumption is around 12l per 100km. thats with Bluefin too.
poor GTI really needs a good country trip to stretch her legs and drop that consumption
My GTI got 6.9 l/100km from Penrith to Brighton le Sands, that's 70/30 highway to Urban. and I did fang it a couple of times. So that's what my MFD says and it usually isn't that far off.
I'm surprised with some GTI drivers about getting figures in the 12s, I only get that if I'm driving on S in the Curvy bits of the Royal NationalMY08 Candy White Golf GTI DSG
Only way I can do less than 10L/100km is by driving like a grandma.
Mind you my fuel consumption seems a bit lower with the DSG behaving itself.
I've found sitting on 120km/hr in the wee hours of the morning has me doing genuine sub 7L/100km figures. Strange because it uses a tad over 7L/100km if I sit on 100.
On hot days it absolutely chews through the expensive stuff. I don't consider it unreasonable, although the performance leaves alot to be desirable..very sluggish.
MFD is usually pretty accurate to what I calculate from the petrol bowser (in my case anyway).
That's the downside to having a "snail" under the bonnet.On hot days it absolutely chews through the expensive stuff. I don't consider it unreasonable, although the performance leaves alot to be desirable..very sluggish.
MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
Yes but don't say you wouldn't like a snail or a blower under your bonnet as well as the big lump.Originally posted by FJ Steve View PostThat's the downside to having a "snail" under the bonnet.
Cheers,
Trent
Edit: I use a little bit more on average than what Balkanac said most likely due to a slightly heavier right foot. The CAI did make a difference of about 1L/100km less though as well. On long highway journey's I can get the consumption down to about 9-10L/100km. Best I've seen is 8.8L/100km. The MkV has slightly better economy I believe due to slight modifications to exhaust, intakes etc which also is what gives it that slight power gain. But as others have said if you're caring a lot about fuel economy you shouldn't really be looking at a GTI or R32. Have a look at the different GTs for fuel efficiency with a little bit of fun thrown in as well.
Edit2: Thanks Balkanac. That makes three out of it comments on my behalf over the last few days now.Last edited by Treza360; 09-03-2009, 06:57 PM.sigpic
I'm going to say nothing on a thread about economy except
