R32 head design Mk4 - Mk5
  • R32 head design Mk4 - Mk5
    Does anybody know if the R32s Mk4 & Mk5 share the same exhaust manifold design?
    Are the outlet spacings and bolt spacings the same? IE will a turbo manifold for a MK4 fit a MK5?
    The flange is the same, but the clearance to the firewall is completely different - (A MK5 has heaps more)
      Thanks Guy
      Do you know what the compression ratio is on the MK5 R32, and if there are any gaskets (or decompression plates) out there (for the MK5) that will lower the compression slightly.
        well this sounds good so far.
        mk4 the mods begin for round 2 hahahha
          Sorry Sharkie - never looked that up - info should be on the web somewhere...
            Off topic, but just a FYI
            2004 R32 Turbo with 22psi boost runs a 11.378qtr .....
              http://www.dragtimes.com/2004-Volksw...eos-15409.html
              Would be interesting to find out the full spec for that car, the American delivered R32s had a slightly different spec to our MkIVs.
              I believe the MkV R32 gains the extra power gains through a different intake and a different exhaust setup. Not 100% sure though on whether the specifics though. I'd say the MkV also meets later EU emission specs as well. I believe the latest/last version of the 3.2L motor also had FSI technology. Whether those engines made it here I don't know.
              Best bet for a American biassed result on this would be to contact HPA over in Canada, with your questions.
              Also Miltek don't list an exhaust manifold for the MkV but they do for the MkIV. Whether they're a straight swap, the MkV manifold is better or equal or it doesn't fit at all, I don't know?
              More questions than answers now, sorry.
              Cheers,
              Trent
                The R32 engine does not have FSI, no country received a FSI engine in the R32 as it doesn't exist.
                The R36 has FSI.
                website: www.my-gti.com
                  Did a little more reading. You are correct that the MkV R32 had no FSI in any country. This is due to longitudinal layout of the 3.2L in the R. Due to the transversal mounting in the current Passat, the 3.2L in it does have FSI. Has the same power as the R but more torque in the model here in Australia (can't be bothered looking to see how different the revs are).
                  Cheers,
                  Trent
                    Cheers,
                    Trent
                    That's a different engine from Audi not from VW.
                      Most inbred confusing lineup ever.
                      Oh and wikipedia can get stuffed too.
                      Sorry for getting 3.2 times off topic.
                      Cheers,
                      Trent
                        Cheers,
                        Trent
                        Wikipedia shows this
                        And it's listed as an Audi engine.
                          Yeah I saw that.
                          Problem is that the VR6 articles says that the latest 3.2 and 3.6 VR6s feature FSI.
                          Passat article also says that it's a VR6 FSI.
                          Gogo consistency and accuracy. Let this be a lesson to all you kids out there that wikipedia is far from the be all and end all.
                          Looking at the article you posted and pretty much everywhere else say that yes the 3.2 FSI is from Audi.
                          Cheers,
                          Trent
                            I had a mk5 2008 R32 in for service the other day and as curious as to the whole FSI thing since I saw a 3.2 Passat had an FSI sticker on it . The MK5 does have FSI ! Next time one comes into the shop I'll take a picture of it and get a picture of a mk4
                              I'm not arguing what you've seen Seb.
                              From what I've seen & the training manual's/data, the Mk5 R32 engine does not have the FSI setup. This is basically the same setup as a Bora 4 Motion.
                              The R36 does have FSI though.
                              The FSI setup on the 3.2 V6's was first introduced in the 3C (current version) Passat 4 motion about a year after it was released. Long before the R36!
                              Don't believe everything you read on Wiki(lie)pedia.
