g'day dubbers, I need some advice from you about what my next step should be?
I few months back, the tyre pressure warning came up on the dash, pulled into a servo and sure enough one of the tyres was down to 20PSI. Pumped it back up, took it to my local K-Mart tyre and auto to have it looked it. Got it back a few hours later and was told 'couldn't find a problem, no charge'.
Since then every few weeks I'd have to pump the same tyre up every so often as it's the only one which slowly deflates.
Just got my Jetta service yesterday (15k). I mentioned that one of the tyres had been slowly deflating and every month or so I'd need to put in a about 10PSI.
They pulled it off the rim and had a look. There were 2 conclusions from the service department:
1. That someone had previously taken it apart, put a patch on the inside of the tyre to fix a small puncture. The patch didn't completely fix the leak, as evident by having to pump it up every few weeks.
2. Whoever took it apart last time wasn't very careful and had damaged the 'bead' of the tyre, but had realised they had done it and put some 'bead seal' on it.
They recommended to have the tyre replaced as soon as possible.
Quote for one Bridgestone RE050A (225/40/R18 ) was $495.
They also recommended me to go back to the K-Mart place and talk to the guys to find out exactly what happened and if it was the case that they had damaged the tyre bead, then I'd be entitled to have the tyre replaced by them.
As far as I'm aware, the only people to have access to the tyre were:
1. The dealer when I bought car. (Wheels and tyres were dealer fitted)
2. My local K-Mart tyre and auto.
3. Volkswagen dealer service.
The cost is a factor but if it came down to it, I'll pay $500 for the tyre.
And I threw away the paperwork the K-Mart gave me as they said there was no problem so I didn't see a point in keeping it.
What do you think I should do?
Thanks!
Thanks!
