passenger seat sensor
  • passenger seat sensor
    is it possible to turn the sensor off on the passenger side that beeps when the seatbelt isnt in when there is a 'passenger' in the car...
    i ask as when i put something remotely heavy on it starts beeping even tho its not a person...
    hope that makes sense
    What do you want to put in the passenger seat that won't get in the way during a collision?
    I don't advocate putting anything on the passenger seat other than a person. Animals should be strapped in the back and anything else that can't fit in the numerous compartments and door pockets should be in the boot.
      if its like bmw's the sensor also is used for the airbag - in which case if you disable it the car will always think there's no one in the seat and not activate the airbag- BAD.
      also they are usually more than just a switch so need a specialist circuit with resistors and diodes.
      Best to leave it alone.
      had a passat tdi. now mb c class.
        Both front air bags deploy no matter what occurs. I'm pretty sure that BMW operate this way as well.
        You can turn it off using VCDS/Vagcom or by a heap of other ways.
        website: www.my-gti.com
          There's a thread about 5 down from your new one that covers all of this in details. Remember search is your friend and saves you having to ask what has already been covered before.
            thanks for all your help
            think ill just leave it as is
              Agree. Leave it alone.
