Hi all,
Engine light came on just earlier. Scanned the car and got this code:
I did some research online and surprisingly what I found wasn't straightforward with people referring to different sensors, some people talking about wiring issues etc.
Is it the sensor bolted into the bottom of the oil pan?
I came across posts also mentioning a 2nd oil temp sensor located at the top of the engine or near the oil filter.
VCDS seems to indicate that the fault sensor is G8 so can someone confirm where it is located?
Thank you
EDIT: Engine code BVY
000406 - Engine Oil Temp. Sensor G8
P0196 - 004 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 166924 km
Time Indication: 0
Date: 2000.00.00
Time: 12:55:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 17.0 C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 166924 km
Time Indication: 0
Date: 2000.00.00
Time: 12:55:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 17.0 C
Thank you
