Hi guys,
I appreciate any advice in advance with this one I'm really banging my head against the wall with it.
I have been working through a bunch of issues on a Mk5 Golf, an auction purchase so fully aware of the buyer beware aspects of that but a lover of the cars all the same.
I have an Airbag Fault warning message, but a lack of the airbag warning light at any stage, including start up (so I am suspicious this may have been covered in the instrument panel but yet to rip that out). The Airbag Control Module is not communicating with VCDS.
As a side issue but possibly related fault, my driver door electrics are not working.
I have done the following:
Scanned VCDS to no avail, clearing any other codes but none relevant.
Checked the connections and used some compressed air for the control module and under seat wiring.
Passenger seat looks to have possible been removed before, the wiring cover is missing.
Removed the a Pillars both sides hoping to have a loose T10p connection from another forum post but there is no wiring in my driver side A pillar at all, which I feel like I should be suspicious about (but not sure).
Checked all fuses.
Disconnected reconnect the battery (have disconnected it for any airbag related tasks).
Looked at the wiring under the dash on the driver side to the best of my ability. There is nothing plugged into 'G' socket but I'm not sure if that's relevant.
I have a replacement control module but I'm reluctant to do anything with this without their being any communication with VCDS.
I have checked every connection I can to a point but I am open to any suggestions.
So let's say a previous owner has tried to hide an airbag fault for a Road Worthy inspection, could they have unplugged or removed a vital piece of the communication wiring from the module to the vehicle that I could potentially find and replace. I'd be very appreciative of any suggestions to try to resolve the issue.
Thank you.
Checked all fuses.
Thank you.
