Hi all, so a couple of days ago my 2009 BKD Golf Pacific developed an amusing problem. The driver's window was going down when the passenger window switch was pushed up (and vice versa), the passenger window was going down when the driver's window switch was pushed up (and vice versa), the electric mirrors were the same (with the addition that up and down translated to left and right (for the opposite mirror of course, haha).
Today it took a more serious turn when the rear doors no longer lock and unlock.
Also, the footwell and door lights haven't worked for a while and the mirror down in reverse function is the same.
Have disconnected the battery for 10 mins and reconnected, no change.
I'm thinking comfort module is to blame, or potentially some corrosion in it's plug or earth connection. Thoughts?
If I was to get a secondhand module from the wrecker, would it need to be coded or is it a straight plug and play.
Any comments / suggestions would be most welcome, especially if there are certain earth points I should be checking / cleaning.
Cheers!
Cheers!
