Running Like a Pig
  • Running Like a Pig
    HI Guys
    I'm after some advice on my Mk5 Golf, 2.0L TDi.
    Start up is a bit on the laggy side, takes a few turns to kick in, runs fine at idle, as well as when you give it the berries.
    The problem is that at low throttle openings, it hesitates, almost stalls.
    To date, i've rebuilt the tandem pump, replaced the MAF sensor and replaced the EGR valve. But the problem seems to be getting worse.
    I'm thinking (hoping) that all ive done is missed plugging in a vacuum hose or something.
    Any thoughts?
    No fault light? Boost leaks are a favourite. SPlit pipes etc
      Scans are clear.
      Hmm, yeah, better recheck the boost pipes as well, thanks for the prompt.
      Sent from my Redmi Note 8 Pro using Tapatalk
        So far, I've tried:
        Replace maf sensor
        Replace egr valve
        Rebuilt the tandem pump
        Swapped around the fuel temp sensor and coolant temp sensor
        Rewired the fuel temp sensor
        Smoke tested the boost pipes
        Smoke tested all the vacuum pipes I can find
        The thing still hates low speed/low revs. It stumbles and pig roots at around 1200rpm, otherwise runs fine.
        Some days are worse than others, gets worse when hot.
        What am I missing???
          So might be a red herring but when was your timing belt done? I was having trouble starting mine, three weeks later the belt went which of course destroyed the engine and I had to fit a new one.
            Only about 80k on the current timing belt.
            Was wondering if its the turbo actuator getting a little sticky...
              Hey are you still having an issue?
              Have you changed the fuel filter recently? If not, change it immediately and pour a diesel injector cleaner directly into the fuel filter canister.
              What about the ASV? This could be caked up with carbon and causing issues. I would also get the timing checked as well.
