Instrument cluster stop working
  • Instrument cluster stop working
    This morning golf mk5 1.9 tdi 2004 year start normal but nothing on dash, car is working, when i turn off and lock-unlock, again start(this i repeat 3 times) , all went back but coolant red light is glowing, what is wrong? No vcds for moment, any clue? Thanks
    Edit, find odbeleven and make scan, this is output:
    OBDeleven vehicle history log Date: 2020-10-19 18:05 VIN: WVWZZZ1KZ5P035557 Car: Volkswagen Golf Year: 2005 Body type: 5-dr hatchback Mileage: 258090 KM --------------------------------------------------------------- Fault Control unit: 01 Engine Active faults: 0 Inactive faults: 2 Software number: 03G906016CB Software version: 6176 Hardware number: 0281011900 Serial number: VWZ7Z0D0565007 Faults: P0671 - Cylinder 1 Glow Plug Circuit static P1654 - Read DTC memory of instrument cluster Intermittent Mileage: 258080 km Date: 2020-10-19 16:32 --------------------------------------------------------------- Fault Control unit: 03 Brakes Active faults: 0 Inactive faults: 0 Software number: 1K0907379K Software version: 0104 Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:32 --------------------------------------------------------------- Fault Control unit: 08 Air Conditioning Active faults: 0 Inactive faults: 2 Software number: 1K0907044AB Software version: 0404 Faults: 00716 - Recirculation flap motor Intermittent 01274 - Back pressure door motor static Mileage: 258080 km Date: 2020-10-19 16:32 --------------------------------------------------------------- Fault Control unit: 09 Central Electrics Active faults: 0 Inactive faults: 3 System description: Bordnetz-SG 1.0 H30 Software number: 1K0937049T Software version: 0704 Hardware number: 1K0937049T * Hardware version: 063 Serial number: 00000000978604 Faults: 01519 - Right back-up light bulb Electrical error in circuit static 01064 - Terminal 58d interior light dimmer Electrical error in circuit Intermittent 00526 - Brake light switch Implausible signal Intermittent Mileage: 258080 km Date: 2020-10-19 16:32 --------------------------------------------------------------- Fault Control unit: 15 Airbag Active faults: 0 Inactive faults: 0 Software number: 1K0909605H Software version: 0700 Hardware number: 1K0909605H Serial number: 00385D0KVN6N Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 16 Steering Column Active faults: 0 Inactive faults: 0 Software number: 1K0953549A Software version: 0030 Hardware number: 1K0953549A * Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 17 Dashboard Active faults: 0 Inactive faults: 2 Software number: 1K0920851H Software version: 0716 Faults: 00003 - Control module Faulty static 00779 - Outside temperature sensor Open circuit/short circuit to B+ Intermittent Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 19 Gateway Active faults: 0 Inactive faults: 0 Software number: 1K0907530E Software version: 0110 Hardware number: 1K0907951 Serial number: 27001049020688 Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 25 Immobilizer Active faults: 0 Inactive faults: 0 Software number: 1K0920851H Software version: 0716 Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 42 Driver Door Active faults: 0 Inactive faults: 2 Software number: 1K0959701E Software version: 0147 Faults: 00943 - Heated outside mirror, driver side Electrical error in circuit static 00913 - Front right window lift switch, driver side Implausible signal Intermittent Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 44 Steering Assistance Active faults: 0 Inactive faults: 0 Software number: 1K1909144G Software version: 1401 Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 46 Comfort System Active faults: 0 Inactive faults: 0 System description: 01 KSG Software number: 1K0959433BL Software version: 0301 Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 52 Passenger Door Active faults: 0 Inactive faults: 2 Software number: 1K0959702E Software version: 0147 Faults: 00944 - Heated outside mirror, frt. pass. side Electrical error in circuit static 00929 - Lock unit for central locking Frt. pass. side Implausible signal static Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 62 Rear Left Door Active faults: 0 Inactive faults: 0 Software number: 1K0959703C Software version: 0213 Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 72 Rear Right Door Active faults: 0 Inactive faults: 0 Software number: 1K0959704C Software version: 0213 Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33 --------------------------------------------------------------- Fault Control unit: 7D Auxiliary Heater Active faults: 0 Inactive faults: 0 Software number: 1K0963235E Software version: 0404 Hardware number: 1K0963235E Faults: No trouble codes found Mileage: 258080 km Date: 2020-10-19 16:33
    From your scan:
    17 Dashboard
    Active faults: 0
    Inactive faults: 2
    Faults:
    Looks like cluster is faulty. Would need to get another one from a wreck and get your immobilizer data transfered over to the replacement using suitable tools such as AVDI, VVDI2, SMOK etc
      Im confused, make otput tests on dasboard and now all gagues and display work, this 00003 error stay and say on google that is radio related,have aftermarket, dont know location of control module from dashboard , is under steering wheel or is located in same dashboard? Thanks
        The dashboard control module is the dashboard itself. The board is behind the gauges.
        If it's working again now then just keep an eye on it see if it recurs.
          I open dashboard cluster to see if some contact is bad, and all seems ok,nothing burnt, little board behind dial boards have capacitors and all is in good condition, must go further and check maybe body control module?
          Can it be that is related to something else?
