The Auto on headlight setting on my Golf, is a bit weird. It regularly turns the headlights on in broad daylight, and keeps them on. Other times it's getting dark due to stormy weather etc, and it won't turn them on. However driving into an underground carpark, always makes them turn on. I can't work out what degree of light triggers it. I have cleaned the windscreen where the sensor is, but makes no difference. Can the sensors be replaced easily? or is it something else? common issue?
Auto on headlights
Tracing problems can be diffcult in these with out it ( actually tracing problems can be difficult even if you do have it )
probably obvious things but ...
HAs the windscreen been replaced?
Is the windscreen clean? The sensor is up the top in the center.
Are there chips in the glass near the sensor?
See replies aboveOriginally posted by saabman View PostTracing problems can be diffcult in these with out it ( actually tracing problems can be difficult even if you do have it )
HAs the windscreen been replaced? - Not Sure
Is the windscreen clean? The sensor is up the top in the center. - Yes
Are there chips in the glass near the sensor? - No, all clearMY08 Golf MkV GT-Sport
A waste of time is what it is. If you drive at highway speed the headlights turn on, but highway speed is 140km/h+ so never gonna happen legally in Australia.Originally posted by BirdManFJ View PostWhat is Highway light function?
A value like 85km/h would make more sense here. I've not heard of any way to change this.MK4 GTI - Sold
MK5 Jetta Turbo - Sold
