GTI Fuel pump
  • GTI Fuel pump
    What's the cost of a replacement fuel pump?
    Any options other than original?
    My car died at work, wouldn't crank. Mechanic down the road thinks it's the fuel pump as he can't hear it priming.
    He can't look at it until Monday.
    If it is the fuel pump what should I expect to pay, including labour?
    Sent from my SM-G965F using Tapatalk
    MY07 Red GTI 3 Door
    fiy my 06 gti fuel pump part number is 1K0919051DB priced at 389.40aud from denlo
    also from research the bosch 69944 should be compatible, you might want to double check though
    i've purchased one off aliexpress before, seems to have the same problem as some aftermarket pumps where you have to keep it above 1/4 tank or it won't be able to draw petrol up properly
    cw.mkv.gti.034ms,s2+
      Thanks Vinny
      Got it fixed today. $940 all up for a Bosch unit.
      I'm sure I overpaid but the car wouldn't start and the mechanics were 50m away.
      I would have taken it to my regular VW specialist but they are 30km away.
      MY07 Red GTI 3 Door
        nice, let me know how the pump goes when you cycle through the entire tank(especially under 1/4)
        did they provide a part number on the invoice by chance?
          What happened when using the aftermarket pump below 1/4?
          Misfire on heavy accelaration or idle?
          Unfortunately no part number on invoice. I'll keep you updated.
          MY07 Red GTI 3 Door
            always had a problem while moving, it'd either feel like it's misfiring or cutout eventually in the timeframe of about 5-10 seconds
            it'd work okay if i let it prime for a few seconds before restarting to limp it to the servo
            took me a while to figure it out the cause though and as it turns out it's fairly common with aftermarket pumps
              I didn't run it down all the way, perhaps that may have caused the original to fail in the first place.
              I let it run down about a notch or 2 below the 1/4 mark but before the low fuel warning light came on. No issues at idle or WOT.
              MY07 Red GTI 3 Door
