Hi all,
Checked my coolant levels just two days back yesterday go for normal drive half way through BAM red light check coolant levels. Pulled over check to find there literally 100ml left in the reservoir.
Is this common in the MK5 for the water pump to just go like that? Luckily my local mechanic was close so re-filled the reservoir and cranked the heating. Really wanted to go to Volkwerke but didn't want it towed. He couldn't look at it until Monday but from where i could see the coolant leak definitely is water pump.
Has anyone replaced with a Hepu or Graf metal impeller pump? Much debate on this some say dont mess about and go OEM.
While hes doing that I might as well replace the tension pulley, idler pulley and belt?
Any advice would be great I never had so many little problems with my R32
