hey peeps
so my newly acquired 08 jetta gearbox needed a replacement 5th /6th gear shift fork - I dropped the end plate and replaced it today.
I adjusted the cables with the selector mechanism on the gearbox locked out, and a 5mm bit in the shifter lockout as well. no more slack in the lines.
the gearstick/selector feels sloppy like loose
I have checked the reverse or shaft slider bushings they're ok
it seems the shifter ball plastic bushing is a bit average, do you guys regularly need to replace these? ?
new to vdubs so just checking in with the usual suspects?
any good threads let me know! '
thanks
thanks
