hello!
i have had a bit of a saga with my mkV TDI.
firstly i got it, it blew a little smoke on full throttle, i didnt really care too much. kept it serviced, topped up with oil and ran fine still getting great fuel economy.
then it started runnign a bit rough at around the 250k kms mark, so i got a timing belt put in.
a few weeks later, she wouldnt start.
replaced EGR
replaced Crank and sensor,
and put a new battery in it.
after i put the crank angle sensor in, she started and ran a few times, but the CEL came on, and my code reader isnt great so i took it back to the mechanic.
the mechanic did a leakdown test, and diagnosed cylinders 2 and 3 as having screwed exhaust valves. Which is evident by the back pressure which is now audible in the air intake box.
According to the mechanic next step is to drop a new engine in there.
i am pretty broke, and have just put the money into the timing belt, EGR, crank sensor, battery and a set of ok second hand tyres on it.
my questions are,
am i getting taken for a ride by the mechanic?
is there anyone who can do a top end rebuild (reseat and replace valves) in Melbourne?
is an engine replacement a reasonable option?
256k kms. otherwise perfect car.
thanks!
replaced EGR
my questions are,
thanks!
