How To Open Boot with key? (Yes I know its a dumb question)
How do you set that up? That would make things so easy for me as my wife loves the doors locked.
Please tell!
If you have the ful size MFD it in the conv. settings - Auto lock, Auto Unlock.
Doors lock when you go over 15km/h.
Unlocks when driver removes key from ignition or 2 pulls of the (inside of course) door handle. 1st pull unlocks that door, second pull opens the door.
If you dont have the full size MFD then VAGCOM is reqd.
Look, all these people are lieing. You cant open the boot that easy.
You need to stand on your head, facing north with a westerly wind, tounge out and push the buttons in the following order. unlock, lock, boot, lock, boot, unlock, lock and unlock at the same time, followed up by the boot for 2 seconds.
No, you can't while the engine is on ... at least, I've never been able to.
The only time I find it annoying is when you're dropping someone off and they have gear in the boot. You actually need to turn the car off, take the keys out, and open the boot.
How about pressing unlock button on drivers side door, next to door handle.....
Hey Maverick, how do i enable the full menu? Dealer can do it for me?
Why didnt they set it up initially!!
You'll need the VCDS/VAGCOM software to do it, I don't know why they disable it but it takes about 10-15 minutes to enable as there is a decimal to hex and back conversion step for the RDL controller. You can then enable/disable the function from the MFD.
If you're in Brisbane I can turn it on at one of the GTG's otherwise you could try some people locally who have a cable.
