hi guys
Hoping someone can offer some advice or suggestions.
I'm having minor electrical problems and on occasion the vehicle won't start without the battery being jumped, but I don't think the battery is the problem, it's still under warranty and is only 18mths - 2yrs old.
Here's the run down;
Charged the battery last week using a 7 stage charger, reconditions, desulphation etc. Drove around for 4 - 5 days, no problems.
Day 6, started noticing my heated seats weren't reaching their normal temp, the headlights flicker when I wind the window up / down, getting a noise coming from my radio which increases with RPM and the cluster has ever so slight flicker. Also once or twice the alarm went off when I started the engine, even though the car was unlocked.
Pulled out the voltmeter and got the following readings immediately after charging the battery (again..)
Car off, Battery reading: 12.65V
At Idle, Battery reading: 13.35V
At Idle, Alternator Case to negative terminal on Battery: 0.02V
At 2,000rpm, Battery reading: 13.25V
At 2,000rpm and under load (Lights, A/C etc.. all on), reading at battery: 13.15V
At 2,000rpm and under load, Alternator Case to negative terminal on Battery: 0.13V
Parasitic draw test which was 0.02amps
There is zero clearance between the alternator and the fan assembly in a 4motion so before I pull the front bar off and put the lock carrier into the service position to start inspecting the alternator, is there anything I have missed??
