Hi guys,
I have a 2003 VW golf mk4 1.6 L BFQ on the clock of 151 Kkm. It has been making issue after issue including sludges in engine oil fixed with flushing, bad idling improved by replacement of camshaft position sensor, malfunctioning O2 B1S1 needed renewing sensor... and the main issues currently are quite frustrating:
symptoms and signs- engine lights on, not smooth start, temperature climbing slowly, both fans on low to middle speed whenever igniting and lasting for a while after removing key. There is no overheating and after a while of driving, temp always reaching a stable 90 C. Now I have to take off the 30A first level fuse to stop the fans.
scan results: 1. 17700/P1292/F265 MAP controlled engine cooling thermostat circuit open, apparently normal cooling temperature sensor G62, with key on ignition, tested near 5 V between negative and positive pins, 0V between two pins of heating plug of Map controlled thermostat ( with temperature sensor G62 plug off). 2. 17811/P1403 EGR system : regulation divergence.
Plan: to fix engine code P1292, now I've ordered a Map controlled thermostat.
Request for help: please give me advice whether to also replace temp sensor G62 or further wiring check (with which I am not good at all). What do you think about the cause of constant fans-on? Is this associated with stat's problem?
Could any one help? Any advice of any is much appreciated.
Jimmy
Jimmy
