Car is MK4 golf 1.6L engine code AVU 167000km on clock
Hi all,
I don't have a check engine light but I know the car is running a bit rich from the smell from the exhaust and its general running. On a scan using VCDS lite I am getting the following codes.
6 Faults Found:
16556 - Fuel Trim; Bank 1: System Too Rich
P0172 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 35-10 - - - Intermittent
16726 - Camshaft Position Sensor (G40): Signal too Low
P0342 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
I think its the MAF sensor. Am I right? The part number is 06a906461B. Anyone recommend a good aftermarket one as the genuine ones arr so expensive
Many thanks
Zeroasylum
Hi all,
6 Faults Found:
P0172 - 35-00 - -
Many thanks
Zeroasylum
