I have been having some random problems lately:
Also I have scanned the engine module in VAGCOM and I get no codes.
I have googled the crap out of these problems and the best I can come up with is the Engine Speed Sensor / Impulse Sender being faulty, but I have no codes... NO FREAKIN CODES.
Any suggestions would be appreciated.
- 1 in 50 starts the car cranks for about 2 seconds longer than usual before the car starts.
- Driving at low speeds and changing out of gear into neutral, the engine will start to stumble and then shut off. During the stumbling, I can presss on the accelerator as much as I want and it does nothing. Almost like there is no connection between pedal and throttle body. But everytime I can restart the car straight away and drive off.
- Cruising at speed and then decide to accelerate, the car will hesitate and then continue on as per normal. The hesitation is very minimal but you can definitely notice it.
- Finally, I still have the problem of the car jerking as if the engine mounts are stuffed when I feather the accelerator on and off. Also when I quickly hop off the accelerator pedal expecting the car to coast smoothly, the car feels like the engine wobbles back and forth. It is concerning when I decide to hope off the accelerator while cornering as its almost enough to unbalance the cars weight. Please note I have brand new engine mounts.
